I'm trying to change the default Geometry node that I slap down at the /obj
level to include some gear that I find useful.
I've rooted around for a bit and I'm not sure where to do this. I presume I can change the geometry type properties, but that's bad, right?
Jerry
Changing default Geometry
6911 4 1-
- jesta
- 311 posts
- VisualCortexLab
- 509 posts
hi,
you can inside your “$home/houdini8.x/scripts/obj” folder.. copy the default geo.cmd from the houdini installation folder (again scripts/obj) and then modify it.. I also modified my own by creating an empty GEO node.. instead of the default cube.
hope this helps
cheers
p.s. here my own for an empty GEO op
# Default script run when a geometry object is created
# $arg1 is the name of the object to create
\set noalias = 1
if ( “$arg1” != “” ) then
opparm $arg1 use_dcolor( 0 )
opcf $arg1
opcf ..
endif
hope this helps
cheers
\set noalias = 1
opcf $arg1
opcf ..
endif
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
- jesta
- 311 posts
- Antoine Durr
- 321 posts
- jesta
- 311 posts
Hi Antoine
At the most basic, I was going to add a render and display sop that i can set using a pre-render script to avoid the doh! factor of seeing a render come back from a wrong flag setting. I just want to idiot proof my stuff.
Then depending on what crops up add more to the geo.
I suggested an RFE to SESI for an output sop where you could wire in what you wanted visible coming out from geometry. For example see attached .jpg.
Cheers
Jerry
Cheers
Jerry
