Offset copy of a curve, how ..?
   3264   4   1
Hi;
How could I create an offset copy of a curve?
something like this image:
Thanks.
Masoud Saadatmand (MSDVFX)
one way could be to create a normalized vector pointing to the wanted direction. Duplicate the curve. Then add this vector multiplied by a float (which value is the desired offset) to the position.
@P = @your_direction_vector * chf("offset");
The vector can't be unidirectional for all the points of course, but needs to be relative to the tangent of the curve (like the arrows in your second picture). The node called polyframe can help you on this. For example you can rotate a vector N as you prefer by using the generated tangent as axis.
FX Artist - Scanline VFX
Thanks “Andrea”, but is there any SOP to do this?
Poly Expand 2D maybe?
Don't have direct experience, but I rmb somebody suggesting it in another thread.
Check it out
Edited by Andr - Feb. 22, 2019 11:04:20
Thank you “Andr”, That's what I need.
