Invert Matrix
   2193   2   1
Hello!
There is the following code and a very strange result which returns the function of inverts. How does the invert function actually work for zero determinant matrices?
matrix3 matA = { {1,2,3}, {4,5,6}, {7,8,9} };
// Find the determinant of the matrix
// If the determinant value is zero, then an inverted matrix cannot be found for such a matrix.
int det = determinant(matA); // det == 0
matrix3 matB = invert(matA); // { {-0.75, 0.5, 0.25}, {-0.5, 0, -0.5}, {0.5833, 0.5, -0.083} }
Maybe in the vex there is some kind of internal error of the data? Because the python strictly refers to this condition.
>>> hou.Matrix3([[1,2,3],[4,5,6],[7,8,9]]).inverted()
  File "<console>", line 1, in <module>
  File "/opt/hfs17.0.497/houdini/python2.7libs/hou.py", line 39294, in inverted
    return _hou.Matrix3_inverted(*args)
OperationFailed: The attempted operation failed.
Hi, I think you're right, VEX isn't handling this case correctly.
The docs say [www.sidefx.com] that if the input matrix is singular (determinant = 0) it should return the original matrix but that clearly isn't happening… Looks like a bug report to me
In the meantime, I guess you could explicitly check the determinant yourself.
