I just switched to Houdini Indie and I installed Redshift. My problem is that Redshift still thinks I have the apprentice version of Houdini so it's not rendering to disk or Mplay and giving this error “The scene can't be rendered due to the Houdini Apprentice license restrictions”. I have a license for Redshift so it's not the demo version. Anyone have knows how to fix this?
Ali
Houdini Indie and Redshift Error
7875 4 2-
- Raytracing6478
- 8 posts
- Midphase
- 833 posts
I made a quick tutorial on how to properly install Redshift with Houdini, this is from an OS X installation but the principles are the same.
It might help you, or it might not, either way here it is:
https://youtu.be/in1XoLH4zRg [youtu.be]
>>Kays
- Midphase
- 833 posts
Also, I thought I'd add…are you trying to open Apprentice files with Indie? If you are, Indie automatically reverts back to Apprentice when you do.
>>Kays
- TwinSnakes007
- 650 posts
- Raytracing6478
- 8 posts
Midphase
Thanks for the Tutorial it's very clear but I've already done these steps and the Redshift plugin works fine inside Houdini and Renders in IPR but not to disk or Mplay so I think it's as Daryl mentioned it's a Houdini license thing.
And your are right about opening older files from apprentice but I tried starting a new scene even an empty one just to see if the error is still there and it is. I'll check with Sidefx guys about the license.
Thanks for the help
