obj import issue
3859 2 0-
- LabMonster13
- 2 posts
- LabMonster13
- 2 posts
For anyone that comes across this issue. The issue seems to be with the .env file I think the quixel bridge, but still need to test to figure it out. I basically made Houdini make a fresh env file and the issue went away. Also of note, mantra rendering was not working as well but with a new env it works again. Hope this info can save someone some time and headaches.
- ocalaf
- 21 posts
LabMonster13
Same happening here I was getting this error in mantra rop: Command Exit Code: -1073740791
I could fix it just commenting the quixel bridge line, so maybe they need to fix something for H17.5, or I will need to make some deeper tests, since I have different HOUDINI_PATH references in the env, and I remember some problems with the “;&” and the end of those path some versions ago (specially then with the GameDevTools).
