Scattering redshift proxies
   6264   3   0
Hi Gang,
I'm wondering if it's possible to use copy to points with redshift proxies? For scattering trees over a piece of geometry. The proxy itself renders fine but when i object_merge it into another network with copy to points all i get is the bounding box. I've no idea what the workflow should be…
cheers,
Andi.
HOUDINI 17.5.173
REDSHIFT 2.6.38
WINDOWS 7
Edited by Andi Farhall - April 26, 2019 11:09:09
rs_proxy_trees.hiplc (780.9 KB)
I think you have to set the redshift obj properties on the sop object to full point scattering or fast-point, not sure which without it in front of me.
I can't find that option anywhere on the object!
cheers,
Andi.
UPDATE:
So, fresh from Juanjo at Redshift…
“Are you trying to instance proxies from the RS Proxy SOP using the copy SOP? This is not going to work at all. The Proxy SOP is there only to preview the proxy in the viewports, but it can’t be used at the SOP level to copy the proxy or things like that. The best workflow to copy/instance proxies is to use the “instancefile” point attribute.”
cheers,
A>
