Reference Ramp
   2601   3   1
Is it possible to have a ramp inside my HDA controller, driving another ramp inside my node tree? RGB or SPLINE ramp, with the ability to add or remove points, change color, retaining all functionality, all done from my master controller. Seems a bit tricky so far.
just like with other parameters
RMB/Copy Parameter on the source ramp label
RMB/Paste relative references on the other ramp label
tamte
yes that worked, for some reason because i copied the parameters from one parameter interface to the other, the ramps were linked without having copied and pasted relative references. maybe it is a bug
tamte
Thanks a lot man you saved my day
