Select Curve Corner Points
   8009   2   1
I'm relatively new to houdini and have been following lots of tutorials and am now attempting to make my own procedural building system.
What I would like to do is find the corner points of a curve and then attach an upright corner support beam to each corner point.
I have tried following peoples advice using the measure tool, selecting curvature and then creating a delete sop setting it to expression and imputing @curvature>5 but that does work. I have a feeling that those instructions are for an older version of houdini as 17.5 doesn't have the same measure tool settings etc some I'm a bit confused!
Can any one advice at all please?
Thanks alot
Joe
Try this:
measure_sharp_corners.hip (68.7 KB)
Hi!
Thanks alot that worked great
Thank you!
Joe
