Create attribute slider in Attribute Wrangle?
   4507   2   1
I am trying to create an attribute slider in the Attribute Wrangle node. In Houdini 16.5 you click on the button on the right (see image) to create it, but I am using Houdini 13 and there is no button. Is there another method I can use to create an attribute with a slider I can more easily change.
You can see the slider "Minmaxangle it created in this screenshot:
https://cdn1.imggmi.com/uploads/2019/6/10/63cd477feaed7ac22649d1859b1bba96-full.jpg [cdn1.imggmi.com]
You'd probably need to go through the edit “edit parameter interface” option under the cog menu and create the slider manually.
@tony_a
How would I actually do this. i.e. create an attribute an use this method?
Edited by litote - June 11, 2019 00:07:21
