Best option for text overlay?
   4959   8   5
Currently using a ROP Composite Output for my text overlays.
Is there a faster/better option? Surprised how slow the node is at completing tasks when compared to the OpenGL ROP that generated the base images. The text overlay seems to be taking about 5x longer than the OpenGL render. And it's memory hungry, too.
Is this the best route to go for a text overlay that echoes wedge values? I'd hate to resort to rendering geo for this, but working on a lone machine and waiting so long for a text overlay gives me time for crazy thoughts…
mC
can't try fixing it without a hipfile…
Hey, cpb…thanks for the reply.
I wasn't posting this as a ‘ROP Composite Output is broken’ kind of thing. Just wondering if this is what people typically use, if the speed I'm seeing sounds normal, and if there are some alternative approaches for text overlays.
If this does sound like an issue with my TOPnet, though, I can try to create a shareable file from the project.
mC
MoltenCrazy
Hey, cpb...thanks for the reply.
I wasn't posting this as a 'ROP Composite Output is broken' kind of thing. Just wondering if this is what people typically use, if the speed I'm seeing sounds normal, and if there are some alternative approaches for text overlays.
mC
Hey did u find any alternative to this..
I face 2 issue
1.taking longer time as compared to opengl
2. I'm getting error on last frame in every wedge.
If my frame range is 1-100 I'm getting error on 100
If I set my frame range from 1-101 I'm getting error on 101.
The error is
"work item 'overlaytext1_ropfetch1_183' lists file as an expected output file, but it wasn't found when the item cooked"
MoltenCrazy
Is this the best route to go for a text overlay that echoes wedge values? I'd hate to resort to rendering geo for this, but working on a lone machine and waiting so long for a text overlay gives me time for crazy thoughts... :P
mC
The fastest approach is using imagemagick for that. The main problem is their caotic docs.
I had to dig a lot and as far as I remember, I've used the generic generator for that, because the image magick TOP node doesn't give you enough options for working with text.
guilhermecasagrandi
MoltenCrazy
mC
Can u share the Hip file please. I'm having trouble using overlay text looking for alternative.
ashutoshm532
guilhermecasagrandi
MoltenCrazy
mC
Unfortunately, I can't share company's assets, but I can help you. Just look for the image magick docs for text generation and then I can help you out.
MoltenCrazy
Hello! Is it possible you forgot to set "all frames in one batch" on the overlaytext top?
i know i did...
Open Image IO Top is a great alternative, I would suggest trying that
