SendmailTOP with attachment?
   3566   3   0
hello,
i do not get the attachment to work, what do I have to use in the attachment field?
thanks a lot
Martin
The “Attachment Tag” parameter should be set to the name of a string attribute which contains the filepath of the attachment.
That being said, there are some RFEs filed to make this a bit more intuitive.
thank You will try it again, maybe I had a error.
ah, it works, I provided the Input. but that did not work, a string attribute works fine. Thank You again
