Curve Node Doesn't save data between unreal sessions
   2274   1   0
Another Unreal Engine Bug, the Curve node doesn't keep any curve point information between session of unreal. posted are two pictures, an initial setup of a curve HDA, and then the same screen-space with the HDA object in world selected, but curve points are not present. any refreshes cause the tool to reset its points to default values. Very simple HDA setup, just a curve node thats been exposed as editable. scene is saved(ctrl+shft+s) between, so everything is being told to save.
Edited by Okari - June 26, 2019 17:22:58
SplineBreakTest.hdalc (24.8 KB)
The issue with editable curves has already been fixed in H17.5.284.
Updating to a more recent Houdini/plugin build should fix the issue.
