Is there a way to convert absolute references to relative references automatically?
2213
1
1
- jajajakob
- 11 posts
I am working on a fully groomed and rigged creature, which should function as HDA at some point.
I used many of the shelf grooming tools and realised too late that they all create absolute channel references.
Is there a good way to convert all these references to relative ones without doing it manually?
As far as I'm aware i would only have to switch “/obj/red_panda/” with “../../” at the beginning of each path.
Thanks in advance!
J
- jjayakumar
- 106 posts
Assuming (from the screenshot) you want to replace path in object merge nodes, something like this might work.
root_node = hou.node("/obj/name_of_subnet")
for n in node.allSubChildren():
if n.parmTuple('objpath1'):
obj_path = n.evalParm('objpath1')
if obj_path.startswith('/obj/red_panda'):
new_path = obj_path.replace('/obj/red_panda/', '../../')
n.parm('objpath1').set(new_path)
Hope it helps
-J
Edited by jjayakumar - July 4, 2019 23:55:54
