Events don't work when terrain is rebuilt/cooked (17.5.308)
   2445   5   0
i attached “HEU_AssetEventReceiverTest” to rebuild, cooked and baked events but nothing gets printed out. Seems they don't get fired when a terrain is rebuilt/cooked or an scattered object is spawned?
Using:
  1. Unity 2019.1.8
  2. Houdini 17.5.308
Thanks,
daschatten
It's working for me. It might be how you setup the callback in Unity. I attached a screenshot of how it should be done with that script.
seelan
You're right… default was “Runtime Only”! Works now. I get the cooked event on “Rebuild Asset”, “Recook Asset” and “Reset Parameters”. In which case is the ReloadCallback fired?
Thanks,
daschatten
ReloadCallback is for Rebuild Asset(Rebuild was original called Reload). I should update the callback name.
Edited by seelan - July 8, 2019 10:48:39
seelan
Reload isn't fired in my test setup, only cooked.
Houdini - Events 01.png (32.4 KB)
Houdini - Events 02.png (30.8 KB)
It is a bug. Tomorrow's daily build will have the fix.
