I have got a textured grid.
How can I let my particles emitting from this grid, inherit the color of the texture?
Example: red part of texture emits red particles, green part emits green particles, and so on…
thanks,
bern
particles inherit color
5823 1 0-
- Bernard
- 523 posts
- graham
- 1926 posts
In order to have your particles inherit the color of the surface they are emitting from, you must have applied a point color attribute.
In this example, an image is read in through a file COP and, using the ‘pic()’ function, is projected onto the grid using the bounding box X and Z values as UV coordinates. This transfers the colors to the points on the grid and allows particles to inherit them. The shader afterwards merely applies a material shader that understands the point color attributes in order for the color to be rendered.
