vop (Bind Node) -''Use Input Value If Parameter Not Bound'' - ?
   3216   2   1
can somebody plz explain me the definition of “bound parameter” & “unbound parameter”? , because it is not properly explained inside docs, or atleast i understood nothing .
thankyou.
By default if an attribute of the same name and type as a Parameter or Bind name/type exists on input geometry it will be automatically used instead of the Parameter value or instead of Bind VOP's default value, in such case that Parameter is considered ‘bound’
You can also specify different binding name for attributes in the Binding tab if applicable
tamte
great bro. thankYou
