i just noticed that my position parameter gives out different values depending on the position (and size of course) of the object
this sounds logical because P means position, but on the other hand i need a “linear gradient mask” (like pos Y should give out a gradient with value 1 on top, and value 0 on bottom) that is independent from changing of P vector (or better say, i need a P based gradient that always fits to 0-1 range).
I need that because i have “gradient masks” are controling intensity of displacement “effect” and such things.
now if i scale my cube 3 times my position based mask ranges are going crazy (i understand P is changing when i'm transforming (move, rotate, scale) a mesh, so i need some kind of range that “autolevels” (i know, i know) my range into 0-1.
so question is:
is there any node or whatever that makes automatically any position range fit into 0-1, so i can tweak that output with a “manual” fit range?
Thank You!
