Execute application from TOPs
   2256   1   1
Is it possible to execute an exe application directly from TOPs, or should I execute it via python, with something like subprocess?
The application takes an argument
x.exe “some_parameter”
You can use the Generic Generator node, and fill out the Command field with the executable + args that you'd like to run.
