Accessing PDG Wedges when instancing / copy_to_points
   2417   1   0
Hi, I'm massively impressed with PDG so far, it's simplified tasks a lot and I'm keen to integrate it as much as I can in my workflows. I have a set up that I will describe below, and i'm wondering if there is a way to use more PDG instead of relying on traditional methods.
What I have done that I like..
My set up is simple:
- I use a mountain SOP on a sphere and use this to generate a basic flip sim.
- In a top network I use a a wedge node to give me 10 variations of the mountain
- I run these 10 variations through the flip sim and with a ROP Geometry Output node, cache PDG style the 10 sims.
So far so good, and It's really nice to be able to work on “one” set-up but it actually be for 10, all without eye-sore for-loops.
However, what I would like to do but don't know how is…
- Take these 10 variations of the sim and randomly instance, or copy them based on the wedges(I guess ‘@wedgeindex’).
- Offset and randomise the time of these wedges for more variation.
After asking around I have found that I can do this by overriding the packed primitive intrinsic of the copy, and referencing the PDG caches when constructing the filename of the packed prim.
“// modify packed primitive instrinsic
setprimintrinsic(0, ”unexpandedfilename“, @ptnum, newpath); ”
However, this feels quite verbose and esoteric when the rest of the PDG workflow is so streamlined.
Is there a way to do this in a cleaner, more PDG integrated way? e.g.. Just using the Top attributes.
Kind Regards,
Tim
Edited by timbolland - Aug. 5, 2019 09:23:22
Hi Tim,
Sorry for the late reply. It's a little hard to follow based on just your description above. Could you kindly submit a file to us? We'll analyze it and get back to you.
- Ken Xu
