Vellum : question about ConstraintGeometry
   1794   1   0
I made a simple setup where the geometry and the constraint have the same point order and prim order in sop.
When I run the sim in dopnet, the prim order of the constraint changes.
I don't understand why . Can someone explain that to me ?
Note, the point order is still the same.
thanks for your help.
Vincent
http://vimeo.com/vbkstudio [vimeo.com]
If I remember correctly prims are being resorted internally based on graph coloring for efficiency
But you can always create some custom attribute (e.g. cns_id) before sim if you need to match the dop level constraints with their sop counterparts
