Houdini size parameters
   2422   3   2
i would like to ask someone to help me confirm that i have the right size setup to finally understand that i am using Houdini size parameter correctly
is this size in houdini bellow
0.018
0.035
0.003
equal to the correct size in MM bellow
18 MM
35 MM
3 MM
if i understand correctly houdini is reading size in meters
so by default this should now read as
0.018 meters
0.035 meters
0.003 meters
by simply doing a Millimetres to Meters conversion
is my understanding correct?
correct size.JPG (199.7 KB)
By size, do you mean for physical simulations, or just for modelling? By default houdini uses meters for simulations, but for modelling there are no units, the numbers are raw values and are open to interpretation. If you import a model with a known scale, then other objects in the world would need to match that scale. Often models from other programs are created in mm or cm, when importing these models, the values a not interpreted, and can therefore appear much larger than anticipated.
jsmack
thank you for that now i understand where i was wrong
yes i was meaning size parameters for Polygonal modeling now i understand the correct way to use houdini
thank you for your help
You can also change the unit length from the Houdini preferences, but I suggest to keep it in meters.
