I wanted to make it so that an HDA with multiple inputs and outputs (like vellum nodes) automatically connects all those inputs.
- I managed to get it to work by pasting the vellum PythonModule script.
I would prefer to have something built-in on inputs-outputs of the HDA, but I guess that's an RFE.
What ways are there to connect the inputs/outputs at once (on vellum nodes)?
I know that you can drop a node on the lines between two connected ones.
I know that you can right-click on an output and type the node name and drop a connected node that way.
Is there a way to connect all inputs/outputs at once,
when you have two nodes in the network view that are not connected, yet?
Make multiple inputs/outputs connect (like on vellum sops)
2105 0 1-
- DASD
- 490 posts
