Pivot Painter won't work?
   3918   1   1
Hello!
I've tried to export "Interactive Grass Example“ to UE4.23 but can't get this work properly.
I've tried different import options (like ”scene convert“ on/off) - no luck at all.
Can you confirm please what ”pivot_painter_demoscene.hip" is still OK for export to UE4 please?
Were you able to get this to work?
I had the same problem that in unreal the whole object rotates as a whole and not the individual cubes.
I got to it work only when I made sure that the output node has name, N, uv, uv1 point attributes. But this replaced the vertex N attribute that I lost the real Normal values.
Actually just got it to work after exporting the pivotpainter node and not any nodes connected to it..
Edited by evrstudio - April 28, 2020 03:03:17
Grant Lee
