Houdini Packages user dir
   6286   5   2
I have my custom location for the user dir, so I want to set HOUDINI_USER_PREF_DIR using Houdini Packages, is it possible?
It doesn't seem to work.
Edited by anon_user_09389530 - Jan. 5, 2020 00:05:10
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
Hi IL,
It works for me I am trying to install qLib tools,I think you have to use HOUDINI_PATH variable, here in this case “path” is shortcut for HOUDINI_PATH as per documentation.
The path top-level key is a convenience for manipulating the $HOUDINI_PATH variable
    "env": [
            "QLIB": "C:/Users/mohan/Documents/GitHub/qLib",
    "path": "$QLIB",
But when I add the HOUDINI_OTLSCAN_PATH, otls are not loading in, and i tried to echo the HOUDINI_OTLSCAN_PATH that doesnt shows up the new variable in the package file , below is the json file content
    "env": [
            "QOTL": "$QLIB/otls",
            "HOUDINI_OTLSCAN_PATH": "$QOTL/base",
    "path": "$QLIB",
Thanks for opening this thread I was also about to do so at the same time, please someone help
Mohan Pugaz
movfx
Hi There is another thread im following about the same issue im facing. no one answered yet.
https://forums.odforce.net/topic/44520-installing-qlib-package-method/?tab=comments#comment-209794 [forums.odforce.net]
Edited by Mohanpugaz - Jan. 5, 2020 05:30:21
Mohan Pugaz
movfx
HOUDINI_PATH works fine for me, the only problem with my user folder.
I tested “path” too but it creates the user folder in the default location anyway.
I did some tests and the only method that works is if HOUDINI_USER_PREF_DIR is set before launching Houdini.
like so
export HOUDINI_USER_PREF_DIR=“/home/dev/customLocationPath/houdini18.0/”
HOUDINI_USER_PREF_DIR can only be set in your environment before launching Houdini.
Adding a custom folder location to HOUDINI_OTLSCAN_PATH for scanning my digital assets seem to be working fine for me.
// This package adds a folder to HOUDINI_OTLSCAN_PATH for scanning digital assets
"env": [
"HOUDINI_OTLSCAN_PATH": [
"${HOUDINI_USER_PREF_DIR}/my_otls"
Edited by mabelzile - Jan. 6, 2020 11:19:29
mabelzile
"env": [
good to know! Everything else works as expected just wanted to clarify about HOUDINI_USER_PREF_DIR
