Setting up .env Houdini 18 for Renderman 23
   10175   13   4
Add an entry to the .env file:
RMANTREE=“C:\Program Files\Pixar\RenderManProServer-23.0”
RFHTREE=“C:\Program Files\Pixar\RenderManForHoudini-23.0”
RMAN_PROCEDURALPATH=$RFHTREE\18.0\openvdb;&
HOUDINI_PATH=$RFHTREE\18.0;&
PATH=$RMANTREE\bin;&
It also helps when an error occurs:
Cannot determine preloaded icons for shelf: <hou.Shelf ‘RenderMan23’>
and
Could not load C:\Program Files\Pixar\RenderManForHoudini-23.0/18.0/lib/rfh_ipr.dll
Edited by w007s - Jan. 8, 2020 05:23:54
I prefer using package
“env” : [
{“RFHTREE” : “C:/Program Files/Pixar/RenderManForHoudini-23.0”},
{“HOUDINI_PATH” : “$RFHTREE/18.0”},
{“RMANTREE” : “C:/Program Files/Pixar/RenderManProServer-23.0”},
{“PATH” : “$RMANTREE/bin”},
{“RMAN_PROCEDURALPATH” : “$RFHTREE/18.0/openvdb”}
- David
dyts
“env” : [
Where to write it? Which file? How is this introduced?
Edited by w007s - Jan. 8, 2020 08:14:35
w007s
dyts
“env” : [
I have a folder “packages” at houdini (on both my mac and PC) and inside all my json files renderman.json, redshift.json …
Capture d'écran 2020-01-08 14.14.03.png (484.8 KB)
- David
w007s
dyts
“env” : [
Take a look at the documentation https://www.sidefx.com/docs/houdini18.0/ref/plugins.html [www.sidefx.com]
Hi David
I am using a direct copy of your text for my package and am getting this..
ERROR: Syntax error in ‘C:/Docs/houdini18.0/packages/renderman.json’
My renderman install in in the right place. Could it be the direction of the slashes?
Best
Mark
Edited by Mark Wallman - Jan. 8, 2020 08:46:35
Hi. In reference to how to set packages up question. I have one windows environment variable to point Houdini to the right location.
variable value: C:\Docs\houdini__HVER__
and then I have added all my packages inside the dir. (see screenshot). I have added a few examples as well so you can see what each package
says.
Edited by Mark Wallman - Jan. 8, 2020 08:53:17
Alicevision.json (116 bytes)
LYNX.json (181 bytes)
MOPS.json (98 bytes)
OTL.json (165 bytes)
SideFXLabs.json (374 bytes)
Can you post the content of the offending package file ? Also you can turn on verbose mode (set HOUDINI_PACKAGE_VERBOSE=1) to get error messages.
Edited by mabelzile - Jan. 8, 2020 08:59:51
Hi Mabelzile
Thanks for replying.
I am still only getting the same error with verbose mode set to 1 (in my UHconfig.json file included here). Do I need to make the package higher up (renaming it something like A_UHconfig.json? like I have to do with Arnold?
Here is my renderman.json file as well. Best Mark
console..
= = = Houdini Package log = = =
Processing ‘C:/Docs/houdini18.0/packages/Alicevision.json’
Processing ‘C:/Docs/houdini18.0/packages/A__HtoA.json’
Processing ‘C:/Docs/houdini18.0/packages/LYNX.json’
Processing ‘C:/Docs/houdini18.0/packages/MOPS.json’
Processing ‘C:/Docs/houdini18.0/packages/OTL.json’
Processing ‘C:/Docs/houdini18.0/packages/renderman.json’
Processing ‘C:/Docs/houdini18.0/packages/SideFXLabs.json’
Processing ‘C:/Docs/houdini18.0/packages/toolbar.json’
Processing ‘C:/Docs/houdini18.0/packages/UHConfig.json’
EDIT: the plot thickens…
I have done just what the docs say..
https://rmanwiki.pixar.com/display/RFH23/Installation+of+RenderMan+for+Houdini [rmanwiki.pixar.com]
and still no joy. I have also made sure the renderman package is top of the list. My latest attempt is called A_renderman.json
Edited by Mark Wallman - Jan. 8, 2020 11:28:59
renderman.json (311 bytes)
UHConfig.json (201 bytes)
A_renderman.json (293 bytes)
Looks like your renderman.json file is using invalid double quotes.
Try with " instead
Edited by mabelzile - Jan. 9, 2020 08:58:38
Hi.
I have gone through and checked the file. doing what you advise. Now it is throwing up even more errors.
Processing ‘C:/Docs/houdini18.0/packages/A_renderman.json’
ERROR: Syntax error in ‘C:/Docs/houdini18.0/packages/A_renderman.json’
ERROR: JSON ERROR: Missing object key (need a string) (near byte offset 255, line 8, column 2)
Here is my text
“env” :
{“RMANTREE” : “C:\Program Files\Pixar\RenderManProServer-23.0”},
{“RFHTREE” : “C:\Program Files\Pixar\RenderManForHoudini-23.0”},
{“RMAN_PROCEDURALPATH=$RFHTREE” : “RMAN_PROCEDURALPATH=$RFHTREE”},
{“HOUDINI_PATH” : “$RFHTREE\18.0;&”,
{“PATH” : “$RMANTREE\bin;&”},
this is line 8:
And I am including my Json file as well. I am coping the exact text from the rmanWiki in my previous post. Best Mark
EDIT: I have just noticed my “ is still different to yours. I'm wondering if this is my text editor. I will check now.
Nope still the same error. I am pressing shift + 2 to get my ”
Sorry for the mass reediting: so the part that seems wrong is the : in this line
{“PATH” : “$RMANTREE\bin”},
I am still non the wiser on what to fix though. Best Mark
Edited by Mark Wallman - Jan. 9, 2020 15:04:34
A_renderman.json (289 bytes)
Hi.
I now have the Json file working. But now I am getting sideFX and renderman software errors..
The specified module could not be found.
Error running pythonrc.py:
File “C:/Program Files/Pixar/RenderManForHoudini-23.0/18.0/python2.7libs/pythonrc.py”, line 47, in <module>
rfh.prefs.init_prefs()
File “C:/Program Files/Pixar/RenderManForHoudini-23.0/18.0/python2.7libs\rfh\prefs.py”, line 223, in init_prefs
_getprefs('rfh', modules)
File “C:/Program Files/Pixar/RenderManForHoudini-23.0/18.0/python2.7libs\rfh\prefs.py”, line 198, in _getprefs
eval(compile('import %s' % fmod, ‘<string>’, ‘exec’))
File “<string>”, line 1, in <module>
File “C:/Program Files/Pixar/RenderManForHoudini-23.0/18.0/python2.7libs\rfh\preset_browser_houdini.py”, line 36, in <module>
from prman import Version as prman_version
File “C:\Program Files\Pixar\RenderManProServer-23.0\bin\prman.py”, line 45, in <module>
class __private: # simple means to keep locals private
File “C:\Program Files\Pixar\RenderManProServer-23.0\bin\prman.py”, line 70, in __private
libprman = ctypes.CDLL(file, ctypes.RTLD_GLOBAL)
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.287\python27\lib\ctypes\__init__.py”, line 366, in __init__
self._handle = _dlopen(self._name, mode)
WindowsError: The specified module could not be found
Hi
I now have it working. If anyone else has the same problems here is my working json file. Best Mark
renderman.json (271 bytes)
Just for anyone who will encounter similar issues.
1. Make sure RenderMan for Houdini is Python 3 version.
2. Use installation via packages (json file). RenderMan has provided a json file at: "C:\Program Files\Pixar\RenderManForHoudini-25.2\packages\renderman_for_houdini.json"
3. Copy-paste this file to: "C:\Users\<YOUR_USERNAME>\Documents\houdini19.5\packages" (houdini<your_version_of_houdini>).
4. Delete everything related to Renderman from houdini.env as json file will do the same and if both are used together, it may cause conflicts. Related post: https://www.sidefx.com/forum/topic/71405/?page=1#post-302661 [www.sidefx.com]
Find "Package installation": https://rmanwiki.pixar.com/display/RFH25/Installation+of+RenderMan+for+Houdini [rmanwiki.pixar.com]
For Houdini 19.0 and beyond, RenderMan for Houdini can be installed with a packages file, found in the RfH installation directory.
Edited by AnimGraphLab - April 21, 2024 03:24:25
Generalist.
Socials: https://linktr.ee/AnimGraphLab [linktr.ee]
