I have set up the nodes shown in the image. I wanted to transform the big sphere when the small sphere comes near it. I can visualize that the attribute is being transferred. But it does not actually transform the big sphere.
1.) Does the attribute transfer not work with the transform node?
2.) Have I connected this wrong way?
3.) what does the attribute transfer return?
Questions regarding attribute transfer node
1535 1 0-
- caspgin
- 2 posts
- Enivob
- 2658 posts
It can only transfer where the vertices meet other vertices. What you can try is to drop down an IsoOffset right after your smaller sphere. Follow that with a Scatter node and increase the count so the entire volume of the small sphere is filled with points. Having more points helps attributeTransfer detect when a nearby point is available to supply new attributes.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
