spacebar + G moves camera really far away
   1977   2   0
Hi I've imported an alembic into my scene and when I try to use spacebar + G to center the geo, the camera moves really far away from the geometry. It behaves normally when doing that function on a cube.
anyone know how to fix this. I need to see my stuff!!!
space + g means home view
object frame is space + f
Home selected and frame selected operations are based on the bounding box of the selection. The alembic may contain a tiny piece that is far from the others or an invisible piece that might cause the bounding box to be much larger than expected.
A work around for homing to a usable distance is to select one or more of the visible components before homing or framing selected.
