Rotating USD UVs with VEX/VOP ?
   3213   1   1
Hi there.
I wish to edit (rotate) UVs on a specific prim within a USD layer reference in Solaris. I tried the TransformUV LOP, however the rotation seems to be only available in object space - I really want to be able to rotate in the UV/map space. Is there a way to achieve this?
Additionally, adding a TransformUV after the Reference node stops all prims from making it to my next node (CopyToPoints) - what's the right way to address this?
Alternatively, can anyone point me to a VEX example for modifying USD data (such as ST attributes) inline?
Hi
The idea here is to move uv's to origin, so its assuming no UDIM's
But this will rotate the uv's by 90 degrees
// move original uv's (st) to origin
vector2 uv = u@primvars:st - 0.5;
matrix UV = ident();
//rotate 90 degrees
rotate(UV,radians(90),{0,0,1});
//rotate the uvs with matrix multi
uv *= matrix2(UV);
//assign to uv's again
u@primvars:st = uv + 0.5;
Hope that helps
Cheers
Edited by jens_martensson - March 1, 2020 17:58:28
Jens Martensson
Effects Supervisor @ Rise VFX
