How can I rotate Normals to 90 degrees?
   15220   7   1
Hi;
Is there any SOP to rotate point Normals of a line (or surface) to 90 degrees?
Thanks for helping.
Normal rotation.jpg (151.7 KB)
Normal rotation.hip (80.1 KB)
Masoud Saadatmand (MSDVFX)
Yeah, you just need to define what axis you want to rotate 90 degrees around.
In this case, it looks like you want to rotate around an imaginary axis that's orthogonal to both the current normal itself, and the axis of the line. To get that orthogonal axis, you can take the cross product of N and the axis that defines the line: this would be normalize(P2-P1).
Then you'd create a matrix or quaternion to rotate the vector with. Quaternions have an easy constructor that take in an axis and angle to define the rotation, which is perfect. You'd convert 90 degrees to radians, then make a vector4 out of that angle/axis pair:
vector4 q = quaternion(radians(90), axis);
Finally, you'd rotate N by that quaternion and then bind the result to v@N:
v@N = qrotate(q, v@N);
So, the complete code:
vector P2 = point(0, "P", @ptnum+1);
vector axis = normalize(P2-@P);
// look backwards if we're on the last point
if(@ptnum == @numpt-1) {
    P2 = point(0, "P", @ptnum-1);
    axis = normalize(@P-P2);
// cross the axis with N to get the final axis.
axis = cross(v@N, axis);
v@N = normalize(qrotate(q, v@N));
not sure what the purpose is, but you can also use Orientation Along Curve SOP, output X axis as N and play with Roll
can i sheepishly ask why not blow away the polyframe
and wrangle @N = {1,0,0}; ?
I know it's a silly question to ask but couldn't resist.
(yes I know it won't work for a slanted line…but…just looking at this straight up line)
Edited by vusta - April 3, 2020 20:24:37
or whatabout this wrangle after the polyframe
vector up = {1,0,0};
@N = cross(@N,up);
this will work for some slanted line.
Edited by vusta - April 3, 2020 20:37:48
Hi “toadstorm”;
I tried your code, but it doesn't work!
tamte
Thank you, very useful SOP.
vusta
@N = cross(@N,up);
Thank you. It works fine.
