Is it possible to deserialize a full graph?
For example, I have a python serialized file but I don't have the original hip file and I would like to deserialize (recreate) all scene nodes.
Ostap
Deserialize a full graph
5010 16 2-
- Ostap
- 209 posts
- chrisgreb
- 603 posts
- Ostap
- 209 posts
- chrisgreb
- 603 posts
Ostapyou create a TOP graph procedurally with HOMBut is it make sense if I can't create dump of my TOP graph?
The TOP ‘dump’ is the hip file. It might make sense to create a TOP graph with HOM if it was part of some higher level automated system.
What's the actual workflow you are looking for? Maybe the `hou.hipFile.merge` function would be useful?
- Ostap
- 209 posts
- chrisgreb
- 603 posts
Ostap
For example for farm wranglers purpose.
It sounds like you mean building a custom UI to view the node graph instead of using Houdini / PilotPDG ?
One thing to note is that the PDG graph is not a 1-1 mapping to the TOP graph. For example there are no subnets, switches or nulls in PDG, in addition without the hip file all the graph layout and node parm formatting is lost.
Edited by chrisgreb - April 17, 2020 12:35:04
- Ostap
- 209 posts
Yes, but also understanding the accessibility of tools for today.
In the beginning, I thought that PilotPDG will satisfy all our requirements (provide full information about PDG graph and be light enough) but looks like the relation between the original Houdini is really tight.
As we already talking about that, can you please share any roadmap/future improvements regarding that?
- chrisgreb
- 603 posts
- Ostap
- 209 posts
- Ostap
- 209 posts
To continue this conversation.
How do you see:
Workitem dependencies visualization if the third person (wrangler) is looking at the farm job of interactive PDG submission?
Workitem dependencies visualization if the graph has been submitted as a job (with Data Server) and the job is not alive anymore (completed, killed ..)?
How do you see:
- Ostap
- 209 posts
- chrisgreb
- 603 posts
Ostap
The data layer server can serve multiple clients. They will just need to connect from PilotPDG or some custom client.
It should be possible to attach a 3rd
At the end of the cook the script serializes the task graph state to a python file to disk. This could be used to load the state of the graph as it was when the cook ended.
Is it possible to start automatically Start Server for any PDG session?Yes, it can be started through the pdgd API.
- Ostap
- 209 posts
Scheduler creates a state server - do you think it is the right way? Maybe better to use some Event Handler for this purpose if it's possible?
That what we are doing right now but it is really slow. To deserialize a PDG graph you have to open the hip file first and sometimes the hip file could be huge. It can take minutes to load all those things.
Also, it is not convenient to change a visualisation workflow which depends on a job state (running, done or failed).
Any idea for a better/faster solution?
- chrisgreb
- 603 posts
Ostap
I think it would depend on the particular workflow you have in mind. Currently we only create a state server optionally based on the scheduler toggle parm.
…really slow. To deserialize a PDG graph you have to open the hip file first and sometimes the hip file could be huge. It can take minutes to load all those things.
There's two ways this could be avoided:
1. Keep hython running when the TOP cook finishes, therefore the state server will be available until the process is explicitly killed.
2. Extend the default state server to use a persistent back-end which can be used to bootstrap a remotegraph TOP in PilotPDG. I am guessing that this would be faster because you don't need to load a hip file.
#2 could be a single workflow if there was some kind of central server to connect the client PilotPDG to the correct back end data. However, we haven't implemented a persistent back end, so it's theoretical at this point
- Ostap
- 209 posts
In case of option #1 we will full up our render machines really fast : )
Option #2 sounds cool!
Is it possible to dump data to the file from a PDG State Server? So if we can't find an alive server then we fall back to predefined directory with dump. Also would be nice to have the option of dump verbosity to prevent really huge files (huge files as it is with Serialized Graph right now).
- chrisgreb
- 603 posts
- Ostap
- 209 posts
