[Q}HDRI iamge in Renderman/Houdini
   6340   2   0
I would like to know how I set up HDRI image for Renderman with Houdini. Is there any way to render HDRI image using Renderman in Houdini?
Thanks,
To,
I'm not proficient with renderman, but I can point you to a link regarding an HDR shop plugin called LightGen for Houdini. You need to download HDR shop (free) to prepare your bracketed digital photos or lightprobe
http//www.debevec.org/HDRShop/
I still haven't tried out the full process yet, but it sounds interesting
TL
I'm not sure specifically what you want to do(although I assume “fiddle with it” ), but there isn't much with regard to Houdini that you need to do assuming you want to render some geometry using renderman with HDR. All the magic is in the HDR maps and the prman shader. There's support in recent versions of prman for this format/approach - check out the in the help for prman 11. As far as Houdini - it's mostly just pointing to your shader.
Another thing to keep your eye on over the next several months is the new OpenEXR format from ILM - it works at 16 instead of 32 bit, but is very clever and ILM uses it heavily in production. It's not useful right now except for app developers, but I'm hoping it catches on since OEXR images are significantly smaller than HDR…
J.C.
John Coldrick
