Lattice node issue with divided box
   1179   1   0
Hi, for some reason when I use lattice node with polygon box that has more than 2 divisions I get a weird result…does anyone know how to fix this?
thx
200501_001_Lattice.hipnc (75.1 KB)
you can change box division as much as you want, since that's your geometry you are deforming so that can be anything
however you are changing Lattice division, which has to match the divisions of your lattice geometry
Lattice SOP is very old and works only with geometry produced by a Box SOP as a lattice Rest Geometry and it's edited version and only when you keep divisions in sync
Edited by tamte - May 1, 2020 02:23:00
200501_001_Lattice_mod.hipnc (228.9 KB)
