I'm not sure what I'm doing wrong here, but I've got a simple file pattern going into a mayaserver begin.
I'm assuming that it has to do with my setup, but cannot figure out what the problem is. Any help would be greatly appreciated
Houdini 18.0.416
Maya 2019.2
I keep getting errors like this:
INFO:__main__:Attempting to connect to sharedserver at ('DE#######DL', 54627)
File “C:/Users/S#######e/AppData/Local/Temp/houdini_temp/TOPSPRoc_A05/pdgtemp/7368/scripts/mayarpc.py”, line 41, in <module>
import maya.standalone
ImportError: DLL load failed: The specified procedure could not be found.
ERROR:__main__:Traceback (most recent call last):
File “C:/Users/S#######e/AppData/Local/Temp/houdini_temp/TOPSPRoc_A05/pdgtemp/7368/scripts/sharedserver.py”, line 381, in <module>
main()
File “C:/Users/S#######e/AppData/Local/Temp/houdini_temp/TOPSPRoc_A05/pdgtemp/7368/scripts/sharedserver.py”, line 368, in main
waitOnPort(net_hostname, port, args.proto_type, args.timeout, proc, log_fname)
File “C:/Users/S#######e/AppData/Local/Temp/houdini_temp/TOPSPRoc_A05/pdgtemp/7368/scripts/sharedserver.py”, line 206, in waitOnPort
raise RuntimeError(“Failed to execute work item. Log file could not be read.”)
RuntimeError: Failed to execute work item. Log file could not be read.
Thanks,
S#######e
