I want to key-frame the enable constraints check box on an object. This would allow me to have the object follow a path and then stop following it and do something else. Unfortunately I have not been able to make this work. Keyframeing the check box from on to off dose not turn off constraints. I thought it might be a bug but I've seen this behavior across multiple versions. Has anyone else had this problem? Is there a trick to make it work?
Keyframing enable constraints does not work
2567 1 1-
- Nathan Apffel
- 52 posts
- toadstorm
- 406 posts
I haven't tried keyframing that attribute directly, but you could instead use a constraint blend in your CHOP network, then keyframe the blend weights between your original channels and your constrained channels. If you only need a binary switch, you could do something similar with a Switch CHOP. Then just add a channel reference for the blend/switch attribute(s) to your object.
