Fixed: Draw Curve not working
   4002   1   1
I am following the following documentation on the Draw Curve tool:
https://www.sidefx.com/docs/houdini/nodes/sop/drawcurve.html [www.sidefx.com]
The documentation states:
1) Click the Draw Curve tool on the Create tab.
2) Hold LMB and drag to draw a curve freehand on the construction plane.
When I click the curve tool, Houdini creates a blue grid which I assume is meant to be the construction plane. However, LMB+drag seemingly does nothing. No curve is drawn. Attempting to draw curves on an object similarly fails.
NOTE: Moving the mouse wheel causes the Radius parameter at the top of the screen to change. Additionally, my View State says ‘StrokeDemo’. I am not sure why this is, since I am working in a brand new document, unless this is Houdini's name for the Draw Curve tool.
I have already reinstalled Houdini but this did not solve the issue.
Thank you,
-Aury
Edited by Futzer - June 7, 2020 20:54:40
draw curve.png (331.7 KB)
Fixed by going to the following directory:
Documents\houdini18.0\otls
And deleting the following file:
strokeDemo.hdanc
This file was apparently providing a custom View State for the Draw Curve tool.
