Python / Multiparm & Json
   3310   4   0
I need your help with python & multiparm, please.
I want to be able to export a json file with all my multiparms with values.
Currently when I use for “parent.parms()” I have all the content of hda.
But how to ask by multiparm(tab) as I can when I ask parent.parmsInFolder()
All multiparms are stored on different folders, when I ask those folders I've no result.
I'm an absolute beginner on Python :/
Thanks in advance for your help & time.
I'm sorry if my question is too basic, but I need to find a way to extract multiparm values on json.
here is a quick function that will gather parameters within specified folder
it's a bit naive as would probably not work as is for nested multiparms or specific folder if more are named the same, but should get you going:
def getAllParmsInFolder(node, folder=""):
    parms = node.parms()
    if folder == "":
        return parms
    else:
        out_parms = []
        for parm in parms:
            if parm.isMultiParmInstance():
                mp = parm.parentMultiParm()
                folders = mp.containingFolders()
                if folder in folders:
                    out_parms.append(parm)
        return out_parms
node = hou.node('/your/node')
parms = getAllParmsInFolder(node, "Line 1")
Edited by tamte - June 15, 2020 00:26:07
thanks a lot, Tamte
I've made a simple test case for multiparm folder.
I try using your code but I'm maybe wrong with the parameters I give. It doesn't compile.
I do not know if it's inside the python
here :
node = hou.node(“/../geo1/subnet1/output0”)
parms = getAllParmsInFolder(node, “Amount”)
or
when I call it on my button
Edited by innocent - June 23, 2020 09:43:52
multibox_py.hdalc (10.6 KB)
