Help me understand Divide>Bricker angle
   1910   2   0
I have a Divide/Bricker node inside a for loop(primitives). Each iteration I'm grabbing the normal of the prim converting it to degrees and feeding the value into the bricker angle. My hope is that I will get an even distribution of squares on any prim no matter the angle.
Unfortunately it's not working. Rotation seems to behave oddly to me, I thought it would just be a projection.
thanks in advance!
Edited by traden1976 - June 18, 2020 13:13:16
Hi Traden,
would be better if you share an exemplary file. Anyways, here is a procedure that does not require a for loop.
rotate:
vector nml = prim_normal(0, i@primnum, 0.0);
3@rot = dihedral(nml, {0,1,0});
v@P *= 3@rot;
divide.
rotate back:
matrix3 rot_back = invert(3@rot);
v@P *= rot_back;
bricker_divide.hipnc (95.2 KB)
Thanks for the reply. That will be a good workaround!
Any guidance on using the bricker's Angle parameter to set it to the angle of a prim? Just curious.
