Redshift ROP + Deadline: extra tokens detected in expression
   4053   2   1
Hi guys!
I installed Deadline recently and normally I have a multiple RS Rops where I define the render folder path with a string parameter in a null node. The thing is when I submit the render job to Deadline with the expression that I use for output I'm getting this error:
(Syntax error - extra tokens detected in expression (/out/Redshift_ROP_HQ_PMs_DWAA/RS_outputFileNamePrefix)).
I 'm defining the folder paths in the null like this: $HIP/render/
And the rest of the expression on the RS Rop is like this: `chs(“../RENDER_PATHS/render_folder”)`$HIPNAME/$HIPNAME.$AOV.$F3.exr
Somebody knows how I have to change the output expression in order to get the render correctly? Here is a screenshot from the expression:
Thanks a lot!
hello, have you found a solution to your question? I am having the same issue when trying to render with Deadline.
Unfortunately not yet .
