I'm trying to make scrolling text out of several Font COPs. Font size (and other properties) may vary per COP. I need a way to auto-align the top of a given Font COP to the bottom of the one that precedes it. Thought I could write an expression in the COP's y-position using the “size” function, but the function doesn't seem to like COPs (only SOPs).
Is there another way to do this? Any ideas welcome; thanks!
aligning different Font COPs
3588 3 2-
- cliffbr
- 1 posts
- Antoine Durr
- 321 posts
cliffbrCouple of options (due to the fact that once you generate an image, you don't really have any geometric info about it any more). 1) do a trace SOP on each font COP's output, and then use the resulting geometry's bounding box multiplied with some constant to offset them. 2) not sure if this is possible, but multiply the black & white non-anti-aliased font COP with a vertical grad picture. Then (somehow) find the maximum pixel value in the result, and that is the highest row of pixels. Measuring might be doable in an expression COP (does this even exist)? or in CHOPs, where if you slurp the whole picture in as a channel, you can use one of the CHOPs functions to get the max value. Neither of these solutions are particularly simple, IMO.
– Antoine
- edward
- 8081 posts
- edward
- 8081 posts
