I still know very little about VEX, and for now i would like to learn more about how i can manipulate the Frame channel to control an Alembic animation.
In my specific case, i have created an umbrella that goes from open (Frame 2) to closed (Frame 120), and would like to figure out how i can make the frames play backwards. Is there a function in VEX that can help me accomplish that whilst giving me a level of control on when to trigger it, and the range of frames i want to use? For instance, i would like the umbrella to open and close very fast to shake the rain off of it.
Any help is appreciated!
Noob question: Manipulating Alembic Frame channel
5291 10 1-
- fabiobasile
- 28 posts
- toadstorm
- 414 posts
Packed Alembic primitives in Houdini have what's called a “primitive intrinsic” attribute called “abcframe” that you can set in VEX in order to change the timing. Confusingly, “abcframe” is in seconds, not frames. To set the timing:
where n is the time in seconds that you want to set each primitive to. You can change “set” to “add” or “multiply” or a few other things too; check the help on setprimintrinsic() for details.
setprimintrinsic(0, "abcframe", @elemnum, n, "set");
- fabiobasile
- 28 posts
- fabiobasile
- 28 posts
- toadstorm
- 414 posts
Sorry, I should have emphasized that this is VEX, not an expression. You can leave the Alembic SOP alone. You want to drop down a point or primitive wrangle, then use that code to modify the timings.
- fabiobasile
- 28 posts
- fabiobasile
- 28 posts
So, i've created a primitive wrangle, and pasted in, and now i'm getting these errors. It seems that @elemnum appears to be an undeclared variable:
setprimintrinsic(0, "abcframe", @elemnum, 4, "set");
Error Invalid source /obj/umbrella_export/attribwrangle1/attribvop1 Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Error in VOP 'snippet1'. Warning: Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Error: Vex error: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50) Failed to resolve VEX code op:/obj/umbrella_export/attribwrangle1/attribvop1 Unable to load shader 'op:/obj/umbrella_export/attribwrangle1/attribvop1'. Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Error in VOP 'snippet1'. Warning Errors or warnings encountered during VEX compile: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50). Warning Vex error: /obj/umbrella_export/attribwrangle1/attribvop1/snippet1: Reference to undefined variable: _bound_elemnum (1,37:50) Failed to resolve VEX code op:/obj/umbrella_export/attribwrangle1/attribvop1 Unable to load shader 'op:/obj/umbrella_export/attribwrangle1/attribvop1' Warning Reference to undefined variable: _bound_elemnum (1,27:40)
- toadstorm
- 414 posts
check this file out.
if you want easier control, you can also download MOPs and use MOPs Set Sequence Time to drive packed Alembics or disk sequences.
- fabiobasile
- 28 posts
- fabiobasile
- 28 posts
Progress!
I was able to run the VEX from your file into my wrangle, and now i'm able to delay or shorten my Alembic by changing the second value of fit01().
Now i guess i have to figure out how to reverse the direction of the frames. I've been theorizing that i could perhaps create an array, and somehow play it in reverse using the reverse function, but since frames are stored as seconds of time, maybe there is another way?
- fabiobasile
- 28 posts
Probably not as elegant a solution as i was hoping, i ultimately resorted to dropping a re-time node, and keyframing the top start and end frame channels to key in the exact moment i want the animation to occur, and then keyframe the frame rate to control the speed.
It's a bit convoluted and not as straightforward as i was hoping, but it's a means to an end until i learn a bit more about what i can do with VEX.
