will Redshift for Houdini 0.460 work with 0.520?
   2227   2   0
I just purchased Redshift, versions in program data show it works with Houdini 0.460 but I am using 0.520? will Redshift still work with this version of Houdini?
Most likely no. HDK was changed between those versions. For best compatibility, stick with the same version of Houdini as the HDK used to build the plugin.
jsmack
Thank you for reply. I didn't know Redshift was so dependent on exact version.
