So, as the topic, I am trying to generate a curve node in unreal with python through a button
with the button I used: hou.node(“./”).hdaModule().createFunc(hou.node(“./”))
in the python module:
def createFunc(hda_node): hda_node.createNode functions
So it works fine in Houdini, everything as expected, but this button is not functional in unreal, and is there any way to debug in HDA??
Generate a new node with python script in unreal
2583 2 1-
- JIn_
- 20 posts
- Squarebytes
- 11 posts
- dpernuit
- 560 posts
To debug the issue, the easiest way would be to use session sync.
I see a few things that could cause issues:
- When using HDA and promoting button from another node, that node needs to be set as an editable node in the parent HDA.
- The HDA is locked when used via HEngine, so you won't be able to create nodes inside of it.
You could create nodes inside an editable subnet in the HDA, or outside of the HDA.
