command line render not higher than 1280x720
   1738   2   0
Hi, i'm using this command line sequence to produce images at different resolutions on linux
hython "/opt/hfs18.0.499/bin/hrender.py" -d mantra_ipr -w 1920 -h 1080 -v -o [imageoutput.jpg] [filename.hipnc]
hython "/opt/hfs18.0.499/bin/hrender.py" -d mantra_ipr -w 2048 -h 1080 -v -o [imageoutput.jpg] [filename.hipnc]
hython "/opt/hfs18.0.499/bin/hrender.py" -d mantra_ipr -w 3840 -h 2160 -v -o [imageoutput.jpg] [filename.hipnc]
hython "/opt/hfs18.0.499/bin/hrender.py" -d mantra_ipr -w 4096 -h 2160 -v -o [imageoutput.jpg] [filename.hipnc]
unfortunately all the output images are rendered at the same resolution (1280x720), ignoring the command line flags i specified.
The weird thing is that at very low resolutions (100x100, 200x200, 300x300 etc..) it works perfectly but not at resolutions higher than 1280x720.
I already tried to change the
Override Camera Resolution
option in mantra settings and specify the
User Specified Resolution
but nothing changed.
I also tried the following
-I resolution=100x80
but i receive the error
Error: Unknown argument(s):
Can anyone please help?
Edited by ceusebio - July 23, 2020 10:02:41
houdini resolution issue.png (224.9 KB)
It says non-commercial edition in your screen shot. Are you trying to render from apprentice? If so, then 1280x720 is the tops, bud.
ops… nice. at least now i know why. Thanks man
