Random objects distribution on a line with distortion
   2790   2   0
Hi everyone
I'm looking for the best way to distribute a random selection of objects along a line, making them bend on a curve if necessary, and with an adapted positioning that would make no gaps in case the objects scattered have different dimensions (similar to what Railclone for 3dsmax does!), but i can't find any example i could start with.
Edited by Flatland - July 24, 2020 06:58:20
You can use the new path deformer for example. Copy the geometry to a set of points using a random id for the points, which
represents the different geometries. Using pack geometry allows you to use each piece as a single primitive. The bounding box
functions gives you the lengths of each piece, which can be accumulated.
Here is an example
@edit: new path deform was version 18.0.499
Edited by Aizatulin - July 25, 2020 02:17:01
curve_random_copy.hipnc (404.2 KB)
Oh i like this!
This is well done, you gave me something to study and learn from.
Thanks a lot!
