Curve: multiple primitives to a single primitive? SOLVED
   7797   3   0
Hi!
I used a Carve sop to easily remove sections from it. Now, I'd need to end up with a single primitive per segment. How?
-Olvier
Edited by olivierth - July 27, 2020 11:03:48
Convertline will create a primitive per segment.
Edit:
your screen shot looks like it already has one primitive per segment.
Edited by jsmack - July 25, 2020 21:46:19
I think he means one primitive per larger segment maybe?
The join sop should do the trick with “Only Connected” checked.
Edited by smbell - July 25, 2020 23:39:34
AHH!!
I tried the Join sop before but I did not realize my curve was split at each point!! I used a fuse before join and it works.
Thanks.
-Olivier
