Default Project Path
   1781   1   1
Probably a basic question, but this has been bugging me for while now.
Is it possible to change the default projects folder somewhere ?
When I want to create a new project, it always opens at the “$HOME/HoudiniProjects” location which is located at “C:/Users/….”.
But I never store my projects there. So then I have to browse to my projects folder, but the projects file browser does not accept a path without a file input, which seems like a silly oversight to me.
So then the fastest way seems to type the path manually or copy paste it to the “Projects Path” input field so that I can finally create a new project.
Now if I could just change the default projects folder, it would be a bit less of a hassle. I searched the preferences and tried editing the shortcut but no luck so far.
Thanks,
R.
Edited by toonafish - July 28, 2020 16:35:07
I'm not sure, but you might be able to change that in the Houdini.env file. That can be a bit hard to find, as it is in the hidden directory “Library” under your username on a Mac.
