reference lop default primitive expression doesn't work
   5058   5   0
Weaning myself off sublayers that seem to cause issues in a few places.
Here's a sublayer, all I do is point it at a usd, can see the scene graph path looks as I expect with no more effort:
If I load the same with a reference, I have to manually set primitive path to ‘/volume1’ to match:
I suspected it should be possible to automate, but putting just ‘/’ doesn't work. My mate Ben pointed out that this is what defining the default prim is for, so I went back to the file I'm trying to reference, set the default prim to /volume1, saved.
In the dropdown for the default prim is an expression, ‘Referenced files default primitive’. If I choose it, the expression errors:
Am I misunderstanding the role of this expression? It should be possible to recreate the basic functioanlity of a sublayer without manually typing in a primitive path right?
Does it work with an empty string rather than “/”? With the default prim specified in the reference file the reference shouldn't need any target. However “/” targets the root which is not a valid thing as a far as a reference target goes.
It's just an error in that expression… Change ‘reffilepath’ to ‘filepath1’. I'll correct that.
antc
I thought I tried that, but I'll give it another go. I assume it doesn't otherwise we wouldn't need that expression.
Cheers for the fix Mark!
mtucker
no bug report needed?
Nope, no bug report needed. Thanks!
Edited by mtucker - Aug. 24, 2020 09:01:18
