changing/drawing a ramp curve has no affect on density
   1728   3   0
Hi !
Changing ramp curve in VOPs has no
effect on screen, in other words it's not updating unless I add/change a name parameter of ramp, can anyone check the file ?(look inside ramp1 node) Maybe that's a bug. Work in H 18.566
Edited by Erik Ws - Aug. 28, 2020 08:46:27
test_01.hipnc (137.9 KB)
possible bug (2).jpg (671.0 KB)
that ramp is just the default value of the parameter
the actual ramp is promoted as a part of your volumevop1 node's UI, like all other Parameter VOPs
tamte
Of course, damn..
And how to understand which ramps will be actual and which will be “default value of the parameter”
does ramp vop node always outputs actual ramp outside vopnetwork ?
thank you !
Erik Ws
it literally says Ramp Default
but also it's just how VOPs are designed
but if you want you can wrap Ramp Parameter in the subnet, dive in and change Scope to Subnet Connector
then the Ramp will be promoted to the vop subnet so you will get advantage of using it inside, which is useful for playing with ramps that would be hardcoded in the code and you don't need the users to change or animate
Edited by tamte - Aug. 28, 2020 14:46:20
