Hang on HDA instance rename
   3789   3   1
I'm seeing a new crash in 18.0.566 that occurs when I'm renaming a node that is an instance of an HDA, usually recently (or just) created.
There's no crash log and it technically just hangs forever.
I haven't found repro conditions yet unfortunately but, interestingly, I've seen this in my Mac Indie 18.0.566 and now, just today, my Windows full license 18.0.566.
They have completely different HDA paths and libraries.
The HDAs aren't particular complex, and yet I can't repro reliably.
Anyone see something similar?
EDIT: Just got the hang on renaming an Attribute Wrangle inside an HDA. There were no other dependencies or references to this node in the network (or any other).
I also notice that during the hang Process Manager says about 15% CPU being burned by houdini, so it's still doing…something.
Edited by Len - Sept. 22, 2020 14:17:26
Hi, I have the exact same problem on this version of houdini, I tried disabling all my plugin and resetting the houdini18.0 in document and the problem still occur the same way as described above.
Managed to get a clean repro file and submitted the bug.
Support says it's fixed in 18.0.588. Haven't tested yet.
Got that too recently.
Editing and HDA setup here.
Twitter Video of the Crash [twitter.com]
Edited by smoluck - Sept. 25, 2020 01:24:18
