Loads of keyframes in loads of objects.....
   2281   2   1
So I have lots of things at object level and lots of things in each object with lots of keyframes. Now I want to edit all the fcurves in one go so I need all the keyframed parameters in the animation editor. Do I really have to go into all 60 objects, select all the keyframed nodes and peg them in the animation mixer? Or am I as per usual missing something…..
cheers,
Andi.
this script will add all animated parms in the scene to the animation editor
scopes all keyframed parms in the scene
import hou
animated_list = []
nd = hou.node("/")
nodeArr = nd.allSubChildren()
for n in nodeArr:
    if not n.isInsideLockedHDA():
        parmArr = n.parms()
        for p in parmArr:
            if p.isTimeDependent():
                deletelist = []
                keyframes = p.keyframes()
                if len(keyframes) > 1:
                    p.setScope(True)
cheers,
chrisg
doctorBob you lifesaver,
thank you so much.
A>
